BGP.RIBAbstract.AllocTrackDampPnltyFail
Description
Protocol RIB Abstraction Layer has failed to allocate resources to track a route flap dampening penalty against a BGP route. A penalty will not be tracked against the withdrawn route. If the route is flapping, then Protocol will attempt to allocate a penalty CB the next time the route is withdrawn.
Remedy
This is an internal condition needing technical assistance. Contact technical support with the output of "show tech".
Severity
Warning
Message Text
The Protocol RIB Abstraction Layer has failed to allocate resources to track a route flap dampening penalty against a BGP route. VR = %p1% Route <AFI, SAFI> = <%p2%, %p3%> Route prefix length (bits) = %p4% Route prefix = %p5%
Message Parameters
Name Type
p1 uInt32
p2 uInt16
p3 uInt8
p4 uInt8
p5 HexByteArray
